Hello,
I want to know what is the consequence of having the “Forced Smart Antenna” enabled on the ePMP2000/3000 all the time.
Thanks in advance.
Hello,
Thanks in advance.
You might see sector throughput reduced just in case some SMs are getting better throughput through Sector antenna comparing to Smart Antenna.
Auto mode is recommended when AP automatically evaluate which Antenna can give better throughput for each particular SM.
Thank you.
