FSK and OFDM Frame Calculator Guide
The frame calculator has changed in the 10.2 release of software for the PMP 430 series radio’s.
Attached is a guide for using the FSK and OFDM frame calculators concurrently along with examples. This should help when placing FSK radios and OFDM radios together at or near the same location and calculating the timing correctly for optimal performance.
The attached spreadsheet shows the Tx and Rx timing for both FSK and OFDM radio’s when co-located.
The attached PDF shows examples of a Canopy FSK radio using 9.5 FSK software and a PMP 430 radio using the 10.2 software.
- Frame calculator Quick-guide FSK_OFDM.pdf (178 KB)
- OFDM_FSK_timingdata.xls (266 KB)
