Please assist with this messege from the cambium Sector for me?
Will this have an impact on the data troughput?
The cambium is connected to a 48 voltage battery system with a regulator on.
If a different power supply than Cambium Power Supply is used and "Generic Power Supply" is indicated on the dashboard, please make sure that the power supply wattage is a minimum of 20 watts.
It could possibly cause throughput issues. If the regulator is "dirty" it could be dumping RFI onto the ethernet cable. This will show in your ethernet statistics if it is causes any issues.
