Here is the log from an SM with this issue:
SYSTEM EVENT LOG
01/01/2016 : 00:00:00 UTC : :01/01/2016 : 00:00:00 UTC : :Time Set01/01/2016 : 00:00:00 UTC :
SYSTEM STARTUP
System Reset Exception – Power-On ResetSoftware Version : CANOPY 16.1.1 (Build FACTORY-V7-P1-1) SMBoard Type : P15Board Temperature : 23 C / 73 FDevice Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 111919;01/01/2016 : 00:04:04 UTC : :Web user; user=none; Reboot from Webpage;01/01/2016 : 00:04:09 UTC : :Forced reset;01/01/2016 : 00:04:10 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 16.1.1 (Build FACTORY-V7-P1-1) SMBoard Type : P15Board Temperature : 28 C / 82 FDevice Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 111919;01/01/2016 : 00:07:28 UTC : :Telnet user; user=; PowerOn reset from Telnet command line;01/01/2016 : 00:07:28 UTC : :Telnet user; user=; Reset from Telnet command line;01/01/2016 : 00:07:29 UTC : :Forced reset;01/01/2016 : 00:07:29 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 16.2 SMBoard Type : P15Board Temperature : 31 C / 87 FDevice Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 111919;01/01/2016 : 00:08:19 UTC : Spectrum Analysis for CBRS complete for 10 seconds.;01/01/2016 : 00:10:09 UTC : :Set model to C030045B021A01/01/2016 : 00:10:10 UTC : :Factory Default Completed;User has cleared the log01/01/2020 : 00:00:00 UTC : :01/01/2020 : 00:00:00 UTC : :Time Set01/01/2020 : 00:00:00 UTC :
SYSTEM STARTUP
System Reset Exception – Power-On ResetSoftware Version : CANOPY 16.2 SMBoard Type : P15Board Temperature : 19 C / 65 FDevice Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 111919;01/01/2020 : 00:00:54 UTC : Spectrum Analysis for CBRS complete for 10 seconds.;01/01/2020 : 00:01:08 UTC : :Web user; user=none; Reboot from Webpage;01/01/2020 : 00:01:14 UTC : :Forced reset;01/01/2020 : 00:01:14 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75
No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:00:00 UTC : :01/01/2020 : 00:00:00 UTC : :Time Set01/01/2020 : 00:00:00 UTC :
SYSTEM STARTUP
System Reset Exception – Power-On ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:00:55 UTC : Spectrum Analysis for CBRS complete for 13 seconds.;01/01/2020 : 00:01:55 UTC : :SNMP user; user=snmp; Reboot from SNMP;01/01/2020 : 00:01:57 UTC : :Forced reset;01/01/2020 : 00:01:57 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:02:33 UTC : Spectrum Analysis for CBRS complete for 13 seconds.;12/31/2019 : 17:03:17 MST : :Timezone set to MST;01/22/2021 : 10:33:32 MST : :Time Set01/22/2021 : 10:33:49 MST : :Configuration file “option66.cfg”, triggered from DHCP Option 66, successfully imported.01/22/2021 : 10:33:57 MST : :Factory Default Completed;01/22/2021 : 10:33:56 MST : :Time Set01/22/2021 : 10:34:07 MST : :Time Set01/01/2020 : 00:00:00 UTC : :01/01/2020 : 00:00:00 UTC : :Time Set01/01/2020 : 00:00:00 UTC :
SYSTEM STARTUP
System Reset Exception – Power-On ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:00:51 UTC : Spectrum Analysis for CBRS complete for 13 seconds.;01/01/2020 : 00:05:42 UTC : :SNMP user; user=snmp; Reboot from SNMP;01/01/2020 : 00:05:44 UTC : :Forced reset;01/01/2020 : 00:05:44 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:06:23 UTC : Spectrum Analysis for CBRS complete for 13 seconds.;12/31/2019 : 17:07:07 MST : :Timezone set to MST;01/22/2021 : 10:43:43 MST : :Time Set01/22/2021 : 10:44:01 MST : :Configuration file “option66.cfg”, triggered from DHCP Option 66, successfully imported.01/22/2021 : 10:44:02 MST : :Time Set01/22/2021 : 10:44:06 MST : :SNMP user; user=snmp; Reboot from SNMP;01/22/2021 : 10:44:08 MST : :Forced reset;01/22/2021 : 17:44:09 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75FPGA Version : 120720;01/22/2021 : 17:46:08 UTC : :Error: Unable to start Spectrum Analyzer for CBRS scan.01/22/2021 : 17:46:42 UTC : Spectrum Analysis on boot up complete for 33 seconds.;01/22/2021 : 10:47:42 MST : :Timezone set to MST;01/22/2021 : 10:47:53 MST : :Configuration file “option66.cfg”, triggered from DHCP Option 66, successfully imported.01/22/2021 : 10:48:05 MST : :Time Set01/22/2021 : 10:49:03 MST : :Factory Default Completed;01/01/2020 : 00:00:00 UTC : :01/01/2020 : 00:00:00 UTC : :Time Set01/01/2020 : 00:00:00 UTC :
SYSTEM STARTUP
System Reset Exception – Power-On ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:00:37 UTC : :SNMP user; user=snmp; Reboot from SNMP;01/01/2020 : 00:00:39 UTC : :Forced reset;01/01/2020 : 00:00:40 UTC :
SYSTEM STARTUP
System Reset Exception – User Initiated ResetSoftware Version : CANOPY 20.0.1 (Build STA-1) SMBoard Type : P15Device Setting : 3GHz MIMO OFDM - Subscriber Module - 0a-00-3e-44-8d-75No valid accounts configured. Using default user accountFPGA Version : 120720;01/01/2020 : 00:01:20 UTC : Spectrum Analysis for CBRS complete for 13 seconds.;12/31/2019 : 17:02:05 MST : :Timezone set to MST;01/22/2021 : 10:53:27 MST : :Time Set01/22/2021 : 10:53:42 MST : :Configuration file “option66.cfg”, triggered from DHCP Option 66, successfully imported.01/22/2021 : 10:53:57 MST : :Time Set
SM SESSION LOG
12/31/2019 : 17:02:05 MST : Event: SMSESACTIVATE, NewState: REGISTERING, Flag 0
12/31/2019 : 17:02:05 MST : Event: SMSESMSG, MsgType: SES_AAATMPACCESS, NewState: REGISTERING, Flag 8
12/31/2019 : 17:02:05 MST : Event: SMAUTHORMSG, NewState: REGISTERING, Flag 0
01/22/2021 : 10:53:27 MST : Event: SMAUTHENMSG, NewState: REGISTERING, Flag 0
01/22/2021 : 10:53:27 MST : Event: SMSESMSG, MsgType: SES_CBRS_TMP_ACCESS, NewState: REGISTERING, Flag 12
01/22/2021 : 10:53:27 MST : Event: SMAUTHORMSG, NewState: REGISTERING, Flag 0
01/22/2021 : 10:53:28 MST : Event: SMCBRSMSG, NewState: REGISTERING, Flag 0
repeated 4 times
01/22/2021 : 10:53:29 MST : Event: SMSESINS, NewState: REGISTERED, Flag 12
01/22/2021 : 10:53:29 MST : Event: SMAUTHORMSG, NewState: REGISTERED, Flag 0
repeated 2 times
SM POWER ADJUST LOG
01/22/2021 : 10:53:28 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:53:28 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
01/22/2021 : 10:53:29 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:53:29 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
01/22/2021 : 10:53:30 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:53:30 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
01/22/2021 : 10:54:30 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:54:30 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
01/22/2021 : 10:55:30 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:55:30 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
01/22/2021 : 10:56:30 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:56:30 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 2
01/22/2021 : 10:57:30 MST : Event: SMSESMSG, MsgType: PAREQTO, NewState: REGISTERED, Flag 0
01/22/2021 : 10:57:30 MST : Event: SMSESMSG, MsgType: PASRSP, NewState: REGISTERED, Flag 0
SM AUTHENTICATION LOG
12/31/2019 : 17:02:05 MST : Event: AUTHEN_REQ, NewState: AUTHENTICATING, Flag 0
01/22/2021 : 10:53:27 MST : Event: AUTHEN_EAPSTART, NewState: AUTHENTICATING, Flag 0
01/22/2021 : 10:53:29 MST : Event: AUTHEN_SUC, NewState: AUTHENTICATED, Flag 0
SM AUTHORIZATION LOG
12/31/2019 : 17:02:05 MST : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: IDLE, Flag 0
repeated 1 times
01/22/2021 : 10:53:29 MST : Event: AUTHOR_REQ, NewState: AUTHORIZING, Flag 0
01/22/2021 : 10:53:29 MST : Event: AUTHOR_MSG, MsgType: BCASTKEY, NewState: AUTHORIZING, Flag 0
01/22/2021 : 10:53:28 MST : Event: AUTHOR_REQPARAMS, NewState: AUTHORIZING, Flag 0
01/22/2021 : 10:53:28 MST : Event: AUTHOR_CFGPARAMS, NewState: AUTHORIZED, Flag 0
EAP RADIUS LOG
01/01/2020 : 00:00:40 UTC : Initialized EAP
01/01/2020 : 00:00:40 UTC : Created EAP Instance
01/22/2021 : 10:53:27 MST : Create EAP Session.
01/22/2021 : 10:53:27 MST : Restarted EAP Session.
01/22/2021 : 10:53:27 MST : FULL Restart EAP Session.
01/22/2021 : 10:53:27 MST : SSL client made connection.
01/22/2021 : 10:53:27 MST : EAP SUCCESS For Session
01/22/2021 : 10:53:27 MST : Deleted EAP Session.
01/22/2021 : 10:55:24 MST : Cannot Send Accounting Message because radius server IP is 0
DEVICE AGENT LOG
01/22/2021 : 10:53:41 MST : : Attempting (re)connection in 5 seconds
01/22/2021 : 10:53:42 MST : : Attempting (re)connection in 5 seconds
