Good day. We want to replace Rocket M2 with epmp 1000. Does ePMP 1000 2.4 support the same functionality as version 5ghz? We are interested in - there are problems in use? and no problem with elevate?
The 1000 connectorized and the 5ghz connectorized CPE are almost identical. the only difference is the POE, both support cambium 24v obviously, but the 2.4 can use the UBNT power also the 5ghz cannot.
the GPS verisons of both ONLY support cambium 24. power or standard AT power.
M2 can be elevated, be sure to use the latest firmware and your set.
