HELLO FROM MEXICO
I HAVE 3 PTP LINKS WITH 34 DB DISHES
50 KMS 178 MBPS AGGREGATE 40 MHZ
88 KMS 168 MBPS AGGREGATE 40 MHZ
137 KMS 10 MBPS AGGREGATE 10 MHZ
FIRMWARE 2.3
ALWAYS USE THE MARK UBIQUITI AFTER TALKING TO TAKE MY PROVIDER WITH OPTION TO PROVE CAMBIUM AND A NOTE ON THE PERFORMANCE IMPROVEMENT OF MY NETWORK NOW USE ALWAYS CAMBIUM
Cambium_Sri
(Sriram Chaturvedi)
December 17, 2014, 4:17am
2
Great story, Mario!
What DL/UL ratio are you using or is it Flexible mode?
chung
(chung)
December 18, 2014, 4:42am
4
Snapshot the result is good for everybody to know your goal. Why the longest link only have 10Mhz channel width?
only for test 10 mhz widht and i think works better in 20 mhz widht
now i working in 20 mhz
no problems
any screeshots?
link planner file to study and use as reference for other users?
kindly post in here also.
WARNING !!!!
MAYBE SOME LIMITATION WITH THE NEW FIRMWARE 2.4
IN THE LINK OF 134 KMS AFTER UPGRADE TO FIRMWARE 2.4
LOST CONECTION
MAYBE SOME LIMITATION IN THE RANGE "MAX 65 KMS"
SOMEBODY KNOWS ANYTHING ABOUT???
Brongers
(Brongers)
September 15, 2015, 4:28pm
9
Mario, que pais tienes seleccionado? prueba poniendolo como other.
HOLA YA TENGO SELECCIONADO OTHER DESDE UN PRINCIPIO
NOTE MUCHA DIFERENCIA EN LA LATENCIA MAS BAJA CON EL SOFTWARE 2.5 Y AUMENTARON LOS ANCHOS DE BANDA DISPONIBLES
ehernandezt
(ehernandezt)
September 16, 2015, 9:53pm
11
Hola Mario, una pregunta, que marca y modelo de antenas utilizaste para estos enlaces ?
Me podrias comentar?
wayratel
(wayratel)
October 14, 2015, 6:58am
12
@Mario what country did you use
Hola
use antenas Ubiquiti de 34 db
te recomiendo tambien que actualizes tus equipos al software 2.5
ya que si baja mucho la latencias
saludos
wayratel
(wayratel)
October 15, 2015, 6:41am
15
@ mario can you send me screen shots of access point and SM configuration to my email sheldonles@gmail.com
wayratel
(wayratel)
October 16, 2015, 7:12am
16
@Mario what frequency did you use?confirm if all links are using same
Greetings
Is very good link wow increible
dsomi
(dsomi)
June 10, 2016, 9:05pm
18
Buenas Mario,
con la version 2.5 de Firmware se puede realizar enlaces de mas de 56 Km ?
Intente realizar un enlace de 70Km con el firmware 2.6 y 2.6.1 y me fue imposible.
Muchas gracias.
Saludos.-
Hola buen dia
tengo enlaces activos de 132 y 107 kms
con la version 2.6.1 y sin problemas
estoy usando radios con gps
tengo entendido que al parecer los radios que solo son conectorizados (sin gps) no puedes hacer enlaces de mas de 65 kms
la version 2.4 no me dejaba hacer enlaces de mas de 65 kms
espero te sirva la informacion
saludos
