I have a site with four 4600s on it. It’s a 150 foot tower.
Two of the 4600s show great GPS signals and high SNR numbers.
One of the 4600s shows very weak signals, almost not usuable at this point.
The last 4600 has no GPS at all. This is a new radio with new GPS antenna and in the shop it got great GPS. The old radio and GPS antenna shows great GPS with the unit on the ground.
But the new radio/antennas will not get GPS at all mounted up on the tower.
There is a cell tower about 300 to 400 feet from our tower.
Could these cell transmitters be causing these problems with the GPS on our 4600s?
If so, then maybe moving the GPS antennas that are in the top of the 4600 antennas a few feet might help?
John Rayfield, Jr.
