Can I do take gps sync to a ePMP1000 (C058900P122A) Connectorized equipment through a cmm?
To avoid having to spend on a Connectorized Radio With GPS Sync
Thank you for response.
Hello,
Only GPS Sync units can use an on-board GPS or CMM provided timing signal to allow synchronization of the TDD transmit/receive cycles.
Regards,
Luis
Gracias Luis por la respuesta.
