Any one knows where to buy GPS timing antenna for the CMM? Motorola does not sell them that was what I was told and in order to to get one GPS antenna I’ve got to buy the whole CMM unit.
Did you have one go bad?
Moto says they will never go bad.
But you might try elctro-comm.com
Yup the GPS antena got knock down.
Will try elctro-comm.
hey… our GPS attached to our CMM2 doesn’t show any sign of being active… maybe we have the same case… =(
Antenex, Mobile Mark, Radiall/Larsen, and others make 5VDC active GPS antennas that should work in place of the Motorola, but I haven’t seen a model with an N-type female connector.
