Hello. We've upgraded an AP to 4.4.2 which is a 2k AP and we are unable to upgrade the GPS firmware.
I've attached a screenshot showing the error message when we try to upgrade the GPS firmware with the 4.4.2 file. Once that error showed up, GPS sync also says it's down but 4 customers are still connected.
We're also unable to reboot the radio using the GUI after the attempted GPS upgrade. It acts as if it has rebooted but it doesn't and the uptime does not reset.
After I couldn't get it to reboot with the GUI, I tried upgrading the 2nd bank to 4.4.2 as well and it didn't work but it appears to have rebooted from that upgrade which is unusual. Upon logging back in, the uptime was 40 seconds so it rebooted but the 2nd bank is still on 3.5.6 and did not upgrade.
BUT the GPS firmware shows it is now up-to-date which should not be possible since it never actually completed the upgrade before.
Can someone take a look at this for me? I'm afraid to upgrade our network now that I've found at least 3 bugs or more just on the first sector I upgraded.
I tried upgrading a brand new out of the box 2k AP today to 4.4.2 both banks. Then did the GPS upgrade again and it said it was not required so I waited 7 minutes before power cycling the POE.
When the AP came back online, I receive the following error message in the log: No GPS information received from device. Power reset is required.
I have power cycled it 2 times now and still receive the message. Any ideas how to fix it?
