Hello.
I can’t find the GPS module upgrade for the ePMP2000. I updated to version 5.11, but the GPS didn’t update and I can’t find the file to update it.
The current version is AXN_3.20_8174.
Thank you for your help.
Ronaldo
Hello.
Ronaldo
Hello
Please use the same 5.11 firmware image and place it under the GPS Firmware section on the Firmware Upgrade page.
Okay, thanks friend, problem solved.
Ronaldo
