Here is the event log of a canopy SM - notice anything ? Its really tough to program a Module and set it up when every time you reboot settings are lost and Firmwares alternate back and forth !!
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 425 System Startup Default Parameters Used
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 430 Software Version : CANOPY 8.2.2 SM-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 434 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 444 FPGA Version : 092707
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 448 FPGA Features : DES, Sched
00:07:56 UT : Mon Jan 01 2001 : File src/image_update.c : Line 676 Flash Image Update FAILED INVALIDIMAGEALT
00:09:12 UT : Mon Jan 01 2001 : File src/image_update.c : Line 676 Flash Image Update FAILED INVALIDIMAGEALT
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception –
00:01:12 UT : Mon Jan 01 2001 : File src/image_update.c : Line 676 Flash Image Update FAILED INVALIDIMAGEALT
00:02:02 UT : Mon Jan 01 2001 : File src/http_utils.c : Line 35 Reboot from Webpage.
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1351 System Reset Exception – Watchdog Reset
00:00:00 UT : Mon Jan 01 2001 : System Startup Software Version : CANOPY 9.0 SM-DESSoftware Boot Version : CANOPYBOOT 1.0FPGA Version : 061808FPGA Features : DES, Sched
00:01:09 UT : Mon Jan 01 2001 : File src/http_utils.c : Line 35 Reboot from Webpage.
00:24:12 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1450 Time set
00:25:13 UT : Mon Jan 01 2001 : File src/http_utils.c : Line 35 Reboot from Webpage.
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception – Watchdog Reset
Did you upgrade from 8.2.2 -> 9.0? The proper upgrade path is from 8.2.2 -> 8.2.4 or 8.2.7 -> 9.0
Yeah upgraded to 8.2.2 -> 8.2.4 -> to 9.0 however every time I would process the upgrade to 9.0 it would fail the upgrade. However when rebooted it would boot in 9.0 (most of the time) until I make and changes to the SM .
Are you upgrading locally or remotely? Have you tried 9.3?
SM is sitting next to me and no have not tried 9.3 yet…
*** Solution ***
upgraded to 8.2.7 -> then 9.3 - as 9.0 kept failing on the upgrade over and over
now SM is programmed and after several attempts to reproduce issue it is GONE!!!
thanks to jwelch for suggestions / help
You’re welcome. Thanks for reporting back.
