Hi all,
Just wondering how to translate/understand the number listed by sm under groupable STA? What to spot if fine or have an issue.
Thanks!
Hi all,
Thanks!
That number basically means how many other SM's that SM is in a group with. The higher numbers, the more members in that group, and the more likely it is that two of the members of that group will request and can be sent data at the same instant.
You can find more details related to MU-MIMO in Cambium Knowledge Base:
https://community.cambiumnetworks.com/t5/ePMP-3000-MU-MIMO/bd-p/ePMP_3000_MU-MIMO
Thank you.
