had to delete post
Setting your burst allocation is a good start to dealing with congestion. When you use the default settings your AP ends up running wide open most of the time. 46 subscribers with no bandwidth control is waaay too many for a 900 MHz AP, even if they are all 2X
Would you recommend cutting it by half?
The data rate is controlled.
