Hello Every body!
I have this question:
The Canopy 5200 AP can handle two networks?
That I need is to connect two subscribers and that both subscriber does not see it one to other.
The options that a see are:
a) Put two networks to the AP and connect one subscriber with some network for example 192.168.1.0/24 and the other subscriber with other network for example 192.168.2.0
b) Use just one network and configure the AP to not allow the subscriber access it mutually.
I don’t need to know how made the solution, I just need to know winch can be made it or if you recommend who can be made it, so I can ask that solution to my provider, I ask to you because the only solution that a received of my provider don’t look the best option.
Thank you all, regards.
Look into using the VLAN’s. I believe that will best accomplish what you want to do.
