Hi ,
Please i need to know if i have one sector (HCMP 700 ) and two subscriber connected on this sector , can i take the full capacity from sector ( 338Mbps ) or i can take only the quarter capacity from the sector (84.5 Mbps )
Hi ,
Thank you for the post. I have forwarded this to our development team.
Ray
Hi Mahmoud,
For HCMP mode, there are many link symmetry options at disposal. The User guide provides detailed options, here if you have 40 MHz channel size with 2 Slaves. Assume 300 Mbps is total throughtput and they have same interference and are operating at same modulation rate
If you choose 2:1 then
Master -> Slave 1 = 100 Mbps
Slave 1-> Master = 50 Mbps
Master ->Slave 2 = 100 Mbps
Slave 2 -> Master = 50 Mbps
Hope this helps, let us know if you need more clarification
Sagar
Hi ,
Please check the attached file , only the total sector capacity is 80Mbps with two subscriber module
please davise
