we are building a bse station wuith 6 APs 2400.the colour code code have to be the same for 6 APs or not? same question for the sector id? :?:
If you want redundancy then you can set up the same color codes for your AP’s. This way if one AP fails, and the SM is set to scan other frequencies, then it will pick another AP it can see/talk to. If you only want an SM registering to a specific AP then you will need to have unique color codes. Either way will work and it is all based on your preference or need.
The Sector ID is for your informational purposes only.
