hello,
Im monitoring a canopy network with PrizmEMS. I have all the network managed.
Is there a way to see the accumulative value of traffic? I mean, i can watch the Max RX/TX Bytes, but not he accumulative value of it. Do i make myself clear?
I need to see how much KBytes have been transmitted in the last hour.
Thanks!
This is currently not available as a pre-build view. You would need to export the data to csv and do your own custom reports there.
You can do this from the GUI, or use the Northboud Interface (SDK) to script these.
w18638 wrote: This is currently not available as a pre-build view. You would need to export the data to csv and do your own custom reports there.
thanks... i´ll work at it...
