I want to autoupdate firmware from 13.4 to 14.2 on my PMP450 AP and SM remotely. How do I do that? I am so used to performing manual updates.
Probably the easiest way to do this is to download the free Cambium Network Update Tool or CNUT. You'll need to add a network element, which would be your AP, and then after you've updated the firmware on your AP, you can enable autoupdate on the AP to push the firmware upgrade out to all the SM's registered to it.
