Summary: This article describes how to configure the DHCP Relay feature for cnMatrix Switches. DHCP Relay agent allows the DHCP client and DHCP server in different subnets to communicate with
each other so that the DHCP client can obtain its IP address and configuration.
Note: Even though the feature can be enabled on a VLAN or port, it will relay packets from all
VLANs.
In order for the DHCP Server to know what subnet to provide an IP address for, the Switches will need a Layer 3 VLAN Interface for every VLAN as well as a Layer 2 VLAN. This will then be used as the source address that the DHCP server receives.
CLI
Login to the cnMatrix Switch via SSH or Console
Create the Layer 3 VLAN Interface if you haven’t already, then configure the DHCP Relay commands. In the below example, I will use VLAN 10.
config terminal
interface vlan 10
ip address dhcporip address <IP address> <Subnet>
no shutdown
exit
service dhcp-relay
ip dhcp server <your DHCP server address>
end
copy running-config startup-config
