Use the SM Software Upgrade page to update the device radio software to take advantage of new software features and improvements. From this page you have two upgrade options:
- From URL: A webserver may be used to retrieve software upgrade packages (downloaded to the device via the webserver). For example, if a webserver is running at IP address 192.168.2.1 and the software upgrade packages are located in the home directory, an operator may select option From URL and configure the Software Upgrade Source Info field to http://192.168.2.1/<software_upgrade_package>
- From Local File: Click Browse to select the local file containing the software upgrade package
Procedure:
- Download the software upgrade packages from https://support.cambiumnetworks.com/files/epmp
- Clear the cache of the accessing browser
- On the device GUI, navigate to Tools => Software Upgrade
- Select the SW Upgrade Option which represents the location of your software upgrade packages
- Based on the configuration of SW Upgrade Option, enter either the Software Upgrade Source Info or click the Browse button and locate the software package
- Click Upgrade
- When the upgrade is completed successfully, click the Reset icon
