How many different sub-band radios is required to cover FCC 6, 11, 18 and 23 GHz?
customer is tired on how many different variations needed for license microwave. Due to the diplexer frequenyc range limitation, we still can't use a single radio cover all frequency, but we are making improvement when we move from PTP800/810 to PTP820.
For 1+0, 1+1 or 2+0 with XPIC link, most band can be covered with just two sub-band radio variations:
  • 6L GHz: Two sub-band (Ch1W4, Ch5W8)
  • 6H GHz: Three sub-band (Ch1W6, Ch7W12, Ch13W16)
  • 11 GHz: Two sub-band (Ch1W6, Ch7W13)
  • 18 GHz: One (ChAll)
  • 23 GHz: two sub-band (ChLow, ChHigh)
Using PTP820S as an example:
C060082B009A PTP 820S Radio 6LGHz,TR252A,Ch1W4,Hi,6179.415-6304.015MHz
C060082B010A PTP 820S Radio 6LGHz,TR252A,Ch1W4,Lo,5927.375-6051.975MHz
C060082B013A PTP 820S Radio 6LGHz,TR252A,Ch5W8,Hi,6298.015-6422.615MHz
C060082B014A PTP 820S Radio 6LGHz,TR252A,Ch5W8,Lo,6045.975-6170.575MHz
PTP 820S Radio 6HGHz,TR160A,Ch1W6,Hi,6707.5-6772.5MHz
PTP 820S Radio 6HGHz,TR160A,Ch1W6,Lo,6537.5-6612.5MHz
PTP 820S Radio 6HGHz,TR160A,Ch7W12,Hi,6767.5-6832.5MHz
PTP 820S Radio 6HGHz,TR160A,Ch7W12,Lo,6607.5-6672.5MHz
PTP 820S Radio 6HGHz,TR160A,Ch13W16,Hi,6827.5-6872.5MHz
PTP 820S Radio 6HGHz,TR160A,Ch13W16,Lo,6667.5-6712.5MHz
C110082B001A PTP 820S Radio 11GHz,TR500,Ch1W6,Hi,11185-11485MHz
C110082B002A PTP 820S Radio 11GHz,TR500,Ch1W6,Lo,10695-10955MHz
C110082B013A PTP 820S Radio 11GHz,TR500,Ch7W13,Hi,11425-11725MHz
C110082B014A PTP 820S Radio 11GHz,TR500,Ch7W13,Lo,10915-11207MHz
C180082B005A PTP 820S Radio 18GHz,TR1560,ChAll,Hi,19259-19710MHz
C180082B006A PTP 820S Radio 18GHz,TR1560,ChAll,Lo,17699-18150MHz
C230082B003A PTP 820S Radio 23GHz,TR1200/1232,ChLow,Hi,22400-23020MHz
C230082B004A PTP 820S Radio 23GHz,TR1200/1232,ChLow,Lo,21200-21800MHz
C230082B005A PTP 820S Radio 23GHz,TR1200/1232,ChHigh,Hi,23000-23601MHz
C230082B006A PTP 820S Radio 23GHz,TR1200/1232,ChHigh,Lo,21780-22400MHz
could you please supply the codes for 28Ghz in PTP 820S
example:
C280082B001A PTP 820S Radio 28GHz,TR1008,ChLow,Hi,28556-29005MHz
C280082B002A PTP 820S Radio 28GHz,TR1008,ChLow,Lo,27548-27997MHz
C280082B003A PTP 820S Radio 28GHz,TR1008,ChHigh,Hi,29004-29456MHz
C280082B004A PTP 820S Radio 28GHz,TR1008,ChHigh,Lo,27996-28448MHz
C280082B005A PTP 820S Radio 28GHz,TR1008,ChDX8,Hi,28948-29453MHz
C280082B006A PTP 820S Radio 28GHz,TR1008,ChDX8,Lo,27940-28445MHz
