Product: ePMP1000
Software Versions: 2.6.2, 2.6.1, 2.6, 2.5.2, 2.5.1, 2.5, 2.4.3
Issue/Query: Is there a way to disable or block access to the default or backdoor IP 169.254.1.1?
Solution: We can disable the back door IP 169.254.1.1 access using the below CLI commands as follows.
- config set networkLanDefaultIP 0.0.0.0
- config save
- config apply
Below is the example and command line output:
login as: admin
admin@10.120.200.86's password:
* ePMP1000 command line interface *
ePMP1000_c88d53>
ePMP1000_c88d53>config set networklandefaultip 0.0.0.0
ePMP1000_c88d53>config save
ePMP1000_c88d53>config apply
ePMP1000_c88d53>
Applying the above configuration will reboot the Radio for a short period of time and will come back itself, below is the ping drop time out.
Ping to AP ip address after applying the changes:
To confirm if the radio default ip address is changed to 0.0.0.0, below is the command:
ePMP1000_c88d53>show config
