How to check VLAN traffic on PMP450 AP and SM?
Below is the example configuration on Mikrotik and PMP-450 radios.
Topology :-
PC --> Mikrotik Router(ether2= VLAN-10, ether3= VLAN-20, ether5= Trunk VLAN 10,20) -->AP PMP 450 -->Wireless à SM PMP450 -->Mikrotik -->PC
Configurations on Mikrotik :-
  1. Configuring the trunk port:
                /Interface vlan add name=vlan 10 vlan-id=10 interface =ether 5 disabled=no
                / Interface vlan add name=vlan 20 vlan-id=20 interface =ether 5 disabled=no
  1. In order to forward the packets add bridges:
                /interface bridge add name=br-vlan10 disabled=no
                /interface bridge add name=br-vlan20 disabled=no
  1. Add ports to the bridge
                /interface bridge port add interface=”vlan-10” bridge=”br-vlan10” disabled=no
                /interface bridge port add interface=”ether2” bridge=”br-vlan10” disabled=no
                /interface bridge port add interface=”vlan-20” bridge=”br-vlan20” disabled=no
                /interface bridge port add interface=”ether3” bridge=”br-vlan20” disabled=no
Configurations on PMP450 AP and SM:
On AP:
  • Configuration>> Vlan >> Enable
  • Management VID: 10
  • Allow Frame Types: All Frames
  • Dynamic Learning: Enabled
On SM:
  • VLAN Port Type: Q
  • Management Vlan: 10
  • Default Port VID: 20
How to Verify the specific Vlan traffic hitting AP and SM from network devices:
  • Go under Statistics >> VLAN >> Clear Statistics >> VLAN Statistics Configuration >> select the Vlan in this case its VID =10
  • Click on Save Changes
  • Monitor the Vlan 10 frames hitting the AP/SM under the "Most Recent Filtered Frames"
Interpret entries under Most Recent Filtered Frames as follows:
Unknown— this must not occur. Contact Technical Support.
• Only Tagged— the packet was filtered because the configuration is set to accept only packets that have an 802.1Q header and this packet did not.
Ingress— when the packet entered through the wired Ethernet interface, the packet was filtered because it indicated an incorrect VLAN membership.
Local Ingress— when the packet was received from the local TCP/IP stack, the packet was filtered because it indicated an incorrect VLAN membership. This must not occur. Contact Technical Support.
Egress— when the packet attempted to leave through the wired Ethernet interface, the packet was filtered because it indicated an incorrect VLAN membership.
Local Egress— when the packet attempted to reach the local TCP/IP stack, the packet was filtered because it indicated an incorrect VLAN membership.
I have attached few screen shots for reference.
