How to configure port forwarding on cnPilot R-series
I am informed the last posting was about 5yrs ago, I dont seem to get a way around port fowarding on this Cambium router, i have a web based System running on port xxxx of a computer with ip y:y:y:y and i want it accessible outside but i cant seem to get a way around it.
Never seen an image of cnPilot software.
Well. Same software used by Flyingvoice products. Really interesting…
Hi @Emenyu_Jimmy,
Please find below the steps to configure the port forwarding rule:
Navigate to Network->Port Forward.
Add LAN host {Destination-192.168.11.185} IP address.
Port number/range and protocol.
Try connecting to the router’s WAN IP + port.
Traffic will be forwarded to the destination LAN host.
Please find below an example of the port-forwarding rule.
NOTE: Source IP address was introduced to limit the access to the specific host.
Regards,
Smriti
I tried to use this service and now it looks like is not working, but I don’t if it worked before as I didn’t find anything with a practical example.
The post above is just showing where to make the configuration, it is not showing it working.
Do you have some test?
Thank you so much.
@Julio_Araujo1
Are you only looking for a test case to check if this works or not ?
Or do you need help in setting up port-forwarding to access a LAN host from WAN ?
Please share the scenario which did not work for you.
Yes, I’m traying to set that and I’m not getting, I will share the configuration I did soon.
When I try to access https://xx.x.x.x:80 or x.x.x.x:443. I can see the radio portal but when I try with a different port x.x.x.x:4000 this does not work.
Hi all,
We tested setting in this way below and now it is working.
I know this is an old post but I have a couple of questions. What is the difference between the top half of the Port Forward and the bottom half that says Virtual Servers and which should I use and when. The other question is how to use the Src IP field. Is that for security so only a request from that IP gets access. Does leaving it blank let anybody in?
