Hi Matt.
Kindly guide me on how to configure PTP 450b
I have tried my best but the 2 sites are not comunicating yet
Hi Matt.
Hello Timowanume,
you need to check if the radios you have are able to do a point to point link.
Share us a screen shot of the radio configuration tab. Then, I can guide you further on the configurations.
Sincerely yours,
Niragira Olympe
As Olympe says, a screen shot or two will tell a lot… posting the model number of the radio can also help.
