Dear Sir
I have an Cloud cambium networks at Panipat Refinery Township
In these Two SSID currently used in it
1.PRPC_USER
2 PRPC_GUEST_USER
In PRPC_GUEST _USER How to Block SSID in cloud cambium networks.
OR it cant be Broadcast in the WIFI.
Dear Sir
1.PRPC_USER
2 PRPC_GUEST_USER
To stop broadcasting SSID select WLAN profile --> Under Basic Settings --> Uncheck the "Enable" check box.
This configuration will completly stop broadcasting the SSID(please verify attached image)
Sir,
I have already done these step but SSID wll be broadcasting continously
as well as internet will also provided in it.
After making the changes you need to sync your devices.
You can do this by going to: Application > Sync Configuration
