Summary:
This article demonstrate on how to enable HTTPS on PMP, ePMP and cnPilot devices using cloud cn-Maestro version 2.2.0-r3/r7 releases.
Cause:
For more security reasons we have added https redirection from the cnMaestro and disabled http access. This would affect the cloud account running 2.2.0-R3/R7 and if https is disabled on the devices.
Solution:
Make use of the new templates/AP Group to push to all the devices based on type of the model.
- For PMP, use the below templates and this would help you to enable both HTTP and HTTPS.
Common template for both PMP AP and SM:
"userParameters": {
"networkConfig": {
"webAccess": 2
- For ePMP, use the below template and this would help you to enable only HTTPS not HTTP.
Common template for both ePMP AP and SM:
"device_props": {
"webService": "2"
- For cnPilot devices use the AP Group as stated below:
For E-Series:
Navigate to Configurations > WLANS and AP Groups > Select your AP group > Configuration > Management > Enable HTTPS and Click on “Save” button.
For R-Series:
Navigate to Configurations > WLANS and AP Groups > Select your AP group > Configuration > Management > Web Access > Web Access Protocol > Select HTTP and HTTPS and then click on “Save” button
I hope this helps.
