How to enter southern hemisphere coordinates in Link planner
How do you set link planer to southen hemisphere
I’m not sure what you mean? LINKPlanner doesn’t restrict you to a specific hemisphere.
All coordinates should be entered in the WGS 84 coordinate system, so locations in the southern hemisphere will be negative latitude values or have “s” at the end of the latitude value. The following examples are for the same location:
Your preferences can be modified to change the coordinate display format:
Coordinates can always be entered in any of these formats, regardless of the current display format.
Andy
