Hello!
How I can extract contents of *.pkg3 files?
I need update my canopies in other city.
It cannot be done from my city because latency between 600ms.
I want update my canopies by telnet and ftp.
Thank You.
Hello,
you need the CNUT or prizm 3.1 for the update.
Maico
maico wrote: Hello,
Maico
I can't because latency to canopies about 600ms. CNUT and Prizm3.1 don't works correct.
I want upload extracted files to my remote server, and update network from this server, latency between server and canopies about 20ms. Remote update could be done by ftp and telnet.
Thank You.
Can’t you install CNUT on remote server?
chrisopq wrote: Can't you install CNUT on remote server?
There are no X server or Windows with RDP on remote server.
Only Linux shell.
Ok, I found SMboot.bin on my local Prizm server in /usr/local/Canopy/Prizm/Packages/TFTP-Root/CPY/DES_827B
I tried to update SM through telent and ftp to this version, all fine.
But now I need find APboot.bin and BHboot.bin for update my AP's and BH's.
Where I can get it? Or how to extract *.pkg2 or *.pkg3 files?
http://motorola.motowi4solutions.com/support/community/viewtopic.php?t=4685
BigTrumpet wrote: [quote="antoxa":3m60cdqa]
http://motorola.motowi4solutions.com/support/community/viewtopic.php?t=4685[/quote:3m60cdqa]
I have read this topic, but I'm sure that exists another method to extract files.
Do you know this method?
Anyone still know how to do this?
Link is no longer availble and i need to extract the bin file for a pmp320 SM
Start the update from CNUT, before CNUT has a chance to begin the actual burn, sever your ethernet connection either physically, or by disabling your adapter quickly. Kill cnut or let it time out.
Reconnect and FTP into the radio and download the image file off the device for use uploading to your other devices manually.
No Idea about how the 320 functions because the firmware is a bit different on them if I recall, but this works well for 100, 230, and 450 series canopy devices.
