I'm having a problem to look up the OID to tell me what kind of radio, be 1000 or 2000 per snmp. I've already tried searching the MIB and forums, but I have not found it.
Sorry for my bad english.
Thank you.
Thank you.
.1.3.6.1.4.1.17713.21.1.1.2.0
this will give you a series of outputs, it will tell you what kind of radio you have. a lot more than 1000/2000
Hardware SKU:
-1 - Not available
0 - 5 GHz Connectorized Radio with Sync
1 - 5 GHz Connectorized Radio
2 - 5 GHz Integrated Radio
3 - 2.4 GHz Connectorized Radio with Sync
4 - 2.4 GHz Connectorized Radio
5 - 2.4 GHz Integrated Radio
6 - 5 GHz Force 200 (ROW)
8 - 5 GHz Force 200 (FCC)
9 - 2.4 GHz Force 200
10 - ePMP 2000
11 - 5 GHz Force 180 (ROW)
12 - 5 GHz Force 180 (FCC)
13 - 5 GHz Force 190 Radio (ROW/ETSI)
14 - 5 GHz Force 190 Radio (FCC)
15 - Hawkeye with different clocking scheme for FPGA
16 - 6 GHz Force 200 Radio
17 - 6 GHz Connectorized Radio with Sync
18 - 6 GHz Connectorized Radio
19 - 2.5 GHz Connectorized Radio with Sync
20 - 2.5 GHz Connectorized Radio
100 - (0xe855) ePMP Elevate NSM5-XW
110 - (0xe845) ePMP Elevate NSlocoM5-XW
111 - (0xe8a2) ePMP Elevate NSlocoM2-XW
120 - (0xe6b5) ePMP Elevate RM5-XW-V1
121 - (0xe3b5) ePMP Elevate RM5-XW-V2
130 - (0xe815) ePMP Elevate NBE-M5-16-XW
131 - (0xe825) ePMP Elevate NBE-M5-19-XW
132 - (0xe812) ePMP Elevate NBE-M2-13-XW
150 - (0xe3e5) ePMP Elevate PBE-M5-300-XW
151 - (0xe4e5) ePMP Elevate PBE-M5-400-XW
152 - (0xe885) ePMP Elevate PBE-M5-620-XW
153 - (0xe2c2) ePMP Elevate PBE-M2-400-XW
160 - (0xe835) ePMP Elevate AG-HP-5G-XW
161 - (0xe832) ePMP Elevate AG-HP-2G-XW
170 - (0xe005) ePMP Elevate NSM5-XM-V1
171 - (0xe805) ePMP Elevate NSM5-XM-V2
173 - (0xe012) ePMP Elevate NS-M2-V1
176 - (0xe002) ePMP Elevate NS-M2-V2
180 - (0xe0a5) ePMP Elevate NSlocoM5-XM-V1
181 - (0xe8a5) ePMP Elevate NSlocoM5-XM-V2
183 - (0xe0a2) ePMP Elavate NSloco-M2
193 - (0xe2b5) ePMP Elevate NB-5G22-XM
194 - (0xe2e5) ePMP Elevate NB-5G25-XM
195 - (0xe235) ePMP Elevate NB-XM
196 - (0xe2b2) ePMP Elevate NB-M2-V1-XM
197 - (0xe232) ePMP Elevate NB-M2-V2-XM
220 - (0xe006) ePMP Elevate NS-M6
230 - (0xe215) ePMP Elevate AG-M5-23-XM
231 - (0xe245) ePMP Elevate AG-M5-28-XM
232 - (0xe255) ePMP Elevate AG-HP-5G-XM
233 - (0xe212) ePMP Elevate AG-M2-16-XM
234 - (0xe242) ePMP Elevate AG-M2-20-XM
235 - (0xe252) ePMP Elevate AG-M2-HP-XM
241 - (0xe105) ePMP Elevate RM5-V1-XM
242 - (0xe1b5) ePMP Elevate RM5-V2-XM
243 - (0xe1c5) ePMP Elevate RM5-V3-XM
244 - (9xe8b5) ePMP Elevate RM5-V4-XM
245 - (0xe102) ePMP Elevate RM2-V1-XM
246 - (0xe112) ePMP Elevate RM2-V2-XM
247 - (0xe1b2) ePMP Elevate RM2-V3-XM
248 - (0xe1c2) ePMP Elevate RM2-V4-XM
Device Allocation: AP, SM
cambiumHwInfo.0 gives you what you need. .1.3.6.1.4.1.17713.21.1.1.2.0
it returns 0 for 5GHz ePMP1000 connectorized with Sync. (1000 AP)
it returns 3 for 2.4GHz AP.
it returns 10 for ePMP2000 APs.
Other values are defined as well, covering various available hardware models.
j
cambiumHWInfo OBJECT-TYPE SYNTAX Integer32 (-1|0|1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|19|20|33..39|100..250) MAX-ACCESS read-only STATUS current DESCRIPTION "Hardware SKU: -1 - Not available 0 - 5 GHz Connectorized Radio with Sync 1 - 5 GHz Connectorized Radio 2 - 5 GHz Integrated Radio 3 - 2.4 GHz Connectorized Radio with Sync 4 - 2.4 GHz Connectorized Radio 5 - 2.4 GHz Integrated Radio 6 - 5 GHz Force 200 (ROW) 8 - 5 GHz Force 200 (FCC) 9 - 2.4 GHz Force 200 10 - ePMP 2000 11 - 5 GHz Force 180 (ROW) 12 - 5 GHz Force 180 (FCC) 13 - 5 GHz Force 190 Radio (ROW/ETSI) 14 - 5 GHz Force 190 Radio (FCC) 15 - Hawkeye with different clocking scheme for FPGA 16 - 6 GHz Force 200 Radio 17 - 6 GHz Connectorized Radio with Sync 18 - 6 GHz Connectorized Radio 19 - 2.5 GHz Connectorized Radio with Sync 20 - 2.5 GHz Connectorized Radio 33 - 5 GHz PTP550 Integrated Radio (FCC) 34 - 5 GHz PTP550 Connectorized Radio (FCC) 35 - 5 GHz Force300-25 Radio (FCC) 36 - 5 GHz Force300-25 Radio (ROW/ETSI) 37 - ePMP3000 (FCC) 38 - 5 GHz Force300-16 Radio (FCC) 39 - 5 GHz Force300-16 Radio (ROW/ETSI) 100 - (0xe855) ePMP Elevate NSM5-XW 110 - (0xe845) ePMP Elevate NSlocoM5-XW 111 - (0xe8a2) ePMP Elevate NSlocoM2-XW 112 - (0xe867) ePMP Elevate NSlocoM2-V2-XW 113 - (0xe866) ePMP Elevate NSlocoM2-V3-XW 120 - (0xe6b5) ePMP Elevate RM5-XW-V1 121 - (0xe3b5) ePMP Elevate RM5-XW-V2 130 - (0xe815) ePMP Elevate NBE-M5-16-XW 131 - (0xe825) ePMP Elevate NBE-M5-19-XW 132 - (0xe812) ePMP Elevate NBE-M2-13-XW 150 - (0xe3e5) ePMP Elevate PBE-M5-300-XW 151 - (0xe4e5) ePMP Elevate PBE-M5-400-XW 152 - (0xe885) ePMP Elevate PBE-M5-620-XW 153 - (0xe2c2) ePMP Elevate PBE-M2-400-XW 160 - (0xe835) ePMP Elevate AG-HP-5G-XW 161 - (0xe832) ePMP Elevate AG-HP-2G-XW 170 - (0xe005) ePMP Elevate NSM5-XM-V1 171 - (0xe805) ePMP Elevate NSM5-XM-V2 172 - (0xe003) ePMP Elevate NS-M365 173 - (0xe012) ePMP Elevate NS-M2-V1 174 - (0xe035) ePMP Elevate NS-M3 175 - (0xe2b9) ePMP Elevate NS-M900 176 - (0xe002) ePMP Elevate NS-M2-V2 180 - (0xe0a5) ePMP Elevate NSlocoM5-XM-V1 181 - (0xe8a5) ePMP Elevate NSlocoM5-XM-V2 182 - (0xe009) ePMP Elevate NSloco-M900 183 - (0xe0a2) ePMP Elavate NSloco-M2 190 - (0xe233) ePMP Elevate NB-M365 191 - (0xe239) ePMP Elevate NB-M900 192 - (0xe243) ePMP Elevate NB-M3 193 - (0xe2b5) ePMP Elevate NB-5G22-XM 194 - (0xe2e5) ePMP Elevate NB-5G25-XM 195 - (0xe235) ePMP Elevate NB-XM 196 - (0xe2b2) ePMP Elevate NB-M2-V1-XM 197 - (0xe232) ePMP Elevate NB-M2-V2-XM 210 - (0xe1a3) ePMP Elevate PB-M365 211 - (0xe2a3) ePMP Elevate PB-M3 220 - (0xe006) ePMP Elevate NS-M6 230 - (0xe215) ePMP Elevate AG-M5-23-XM 231 - (0xe245) ePMP Elevate AG-M5-28-XM 232 - (0xe255) ePMP Elevate AG-HP-5G-XM 233 - (0xe212) ePMP Elevate AG-M2-16-XM 234 - (0xe242) ePMP Elevate AG-M2-20-XM 235 - (0xe252) ePMP Elevate AG-M2-HP-XM 241 - (0xe105) ePMP Elevate RM5-V1-XM 242 - (0xe1b5) ePMP Elevate RM5-V2-XM 243 - (0xe1c5) ePMP Elevate RM5-V3-XM 244 - (9xe8b5) ePMP Elevate RM5-V4-XM 245 - (0xe102) ePMP Elevate RM2-V1-XM 246 - (0xe112) ePMP Elevate RM2-V2-XM 247 - (0xe1b2) ePMP Elevate RM2-V3-XM 248 - (0xe1c2) ePMP Elevate RM2-V4-XMDevice Allocation: AP, SM" ::= { cambiumGeneralStatus 2 }</pre>
Updated MIB..
cambiumHWInfo OBJECT-TYPE SYNTAX Integer32 (-1..6|8..14|16..20|22|33..52|100..250) MAX-ACCESS read-only STATUS current DESCRIPTION "Hardware SKU: -1 - Not available 0 - 5 GHz Connectorized Radio with Sync 1 - 5 GHz Connectorized Radio 2 - 5 GHz Integrated Radio 3 - 2.4 GHz Connectorized Radio with Sync 4 - 2.4 GHz Connectorized Radio 5 - 2.4 GHz Integrated Radio 6 - 5 GHz Force 200 (ROW) 8 - 5 GHz Force 200 (FCC) 9 - 2.4 GHz Force 200 10 - ePMP 2000 11 - 5 GHz Force 180 (ROW) 12 - 5 GHz Force 180 (FCC) 13 - 5 GHz Force 190 Radio (ROW/ETSI) 14 - 5 GHz Force 190 Radio (FCC) 16 - 6 GHz Force 180 Radio 17 - 6 GHz Connectorized Radio with Sync 18 - 6 GHz Connectorized Radio 19 - 2.5 GHz Connectorized Radio with Sync 20 - 2.5 GHz Connectorized Radio 22 - 5 GHz Force 130 Radio 33 - 5 GHz PTP550 Integrated Radio 34 - 5 GHz PTP550 Connectorized Radio 35 - 5 GHz Force 300-25 Radio (FCC) 36 - 5 GHz Force 300-25 Radio (ROW/ETSI) 37 - ePMP3000 (FCC) 38 - 5 GHz Force 300-16 Radio (FCC) 39 - 5 GHz Force 300-16 Radio (ROW/ETSI) 40 - ePMP3000 (ROW/ETSI) 41 - 5 GHz PTP 550E Integrated Radio 42 - 5 GHz PTP 550E Connectorized Radio 43 - 5 GHz ePMP3000L (FCC) 44 - 5 GHz ePMP3000L (ROW/ETSI) 45 - 5 GHz Force 300 Connectorized Radio without GPS (FCC) 46 - 5 GHz Force 300 Connectorized Radio without GPS (ROW/ETSI) 47 - 5 GHz Force 300-13 Radio (FCC) 48 - 5 GHz Force 300-13 Radio (ROW/ETSI) 49 - 5 GHz Force 300-20 Radio (FCC) 50 - 5 GHz Force 300-20 Radio (ROW/ETSI) 51 - 5 GHz Force 300-20 IP67 Radio (ROW/ETSI) 52 - 5 GHz Force 300-20 IP67 Radio (FCC) 100 - (0xe855) ePMP Elevate NSM5-XW 110 - (0xe845) ePMP Elevate NSlocoM5-XW 111 - (0xe8a2) ePMP Elevate NSlocoM2-XW 112 - (0xe867) ePMP Elevate NSlocoM2-V2-XW 113 - (0xe866) ePMP Elevate NSlocoM2-V3-XW 120 - (0xe6b5) ePMP Elevate RM5-XW-V1 121 - (0xe3b5) ePMP Elevate RM5-XW-V2 130 - (0xe815) ePMP Elevate NBE-M5-16-XW 131 - (0xe825) ePMP Elevate NBE-M5-19-XW 132 - (0xe812) ePMP Elevate NBE-M2-13-XW 140 - ePMP Elevate SXTLITE5 BOARD 141 - ePMP Elevate COMFAST BOARD 142 - ePMP Elevate LHG5 BOARD 143 - ePMP Elevate Disc Lite BOARD 145 - ePMP Elevate Sextant BOARD 150 - (0xe3e5) ePMP Elevate PBE-M5-300-XW 151 - (0xe4e5) ePMP Elevate PBE-M5-400-XW 152 - (0xe885) ePMP Elevate PBE-M5-620-XW 153 - (0xe2c2) ePMP Elevate PBE-M2-400-XW 154 - (0xe6e5) ePMP Elevate PBE-M5-400-ISO-XW 155 - (0xe5e5) ePMP Elevate PBE-M5-300-ISO-XW 156 - (0xe7e5) ePMP Elevate PBE-M5-600-ISO-XW 160 - (0xe835) ePMP Elevate AG-HP-5G-XW 161 - (0xe832) ePMP Elevate AG-HP-2G-XW 162 - (0xe865) ePMP Elevate LB-M5-23-XW 170 - (0xe005) ePMP Elevate NSM5-XM-V1 171 - (0xe805) ePMP Elevate NSM5-XM-V2 173 - (0xe012) ePMP Elevate NS-M2-V1 176 - (0xe002) ePMP Elevate NS-M2-V2 180 - (0xe0a5) ePMP Elevate NSlocoM5-XM-V1 181 - (0xe8a5) ePMP Elevate NSlocoM5-XM-V2 183 - (0xe0a2) ePMP Elavate NSloco-M2 193 - (0xe2b5) ePMP Elevate NB-5G22-XM 194 - (0xe2e5) ePMP Elevate NB-5G25-XM 195 - (0xe235) ePMP Elevate NB-XM 196 - (0xe2b2) ePMP Elevate NB-M2-V1-XM 197 - (0xe232) ePMP Elevate NB-M2-V2-XM 220 - (0xe006) ePMP Elevate NS-M6 230 - (0xe215) ePMP Elevate AG-M5-23-XM 231 - (0xe245) ePMP Elevate AG-M5-28-XM 232 - (0xe255) ePMP Elevate AG-HP-5G-XM 233 - (0xe212) ePMP Elevate AG-M2-16-XM 234 - (0xe242) ePMP Elevate AG-M2-20-XM 235 - (0xe252) ePMP Elevate AG-M2-HP-XM 236 - (0xe202) ePMP Elevate BM-M2-HP-XM 237 - (0xe205) ePMP Elevate BM-M5-HP-XM 241 - (0xe105) ePMP Elevate RM5-V1-XM 242 - (0xe1b5) ePMP Elevate RM5-V2-XM 243 - (0xe1c5) ePMP Elevate RM5-V3-XM 244 - (9xe8b5) ePMP Elevate RM5-V4-XM 245 - (0xe102) ePMP Elevate RM2-V1-XM 246 - (0xe112) ePMP Elevate RM2-V2-XM 247 - (0xe1b2) ePMP Elevate RM2-V3-XM 248 - (0xe1c2) ePMP Elevate RM2-V4-XMDevice Allocation: AP, SM" ::= { cambiumGeneralStatus 2 }</pre>
