How to generate HTTPS certificates with openssl
Is it possible to generate security certificates for PTP500/650/670 radios (with AES) using openssl. Been trying to generate DER (private and public keys) but unable to make them work.
Many thanks,
Gerry
Some tips from IBM :slight_smile: Upload it after it will be ready :slight_smile: https://www.ibm.com/support/knowledgecenter/SSMNED_5.0.0/com.ibm.apic.cmc.doc/task_apionprem_gernerate_self_signed_openSSL.html
Hi Gerry,
We had a very similar request just yesterday. Please see:
The short answer is “yes, it is possible to generate security certificates for PTP500/650/670 radios”. I guess you were hoping for some detailed procedure. I think it’s best if I try and answer both requests together. Please look to the earlier topic for more information.
Thanks, Mark
Thanks for the suggestion. We don’t recommend using self-signed certificates in the PTP radio. Please see the earlier topic for a longer explanation. We will try to provide a tested recipe for generating keys and certificates.
Thanks, Mark
