Hello,
We need help of getting a total usage from each cambiunm access point per subscriber module -ideally without using cnmaestro?
Any ideas or suggestions?
Appreciate you help on this issue
Hello Sir,
unless you do it from your distribution router.
Otherwise, I do not see any other option without using a monitoring tool.
Sincerely yours,
Niragira Olympe
Hello Olympe,
Appreciate your prompt attention and help
We have a follow up question to your comment:
“what about using snmp to gather the necessary data? If that is possible, what snmp strings might supply the usage data on each SM?”
Hello Sir,
I will have to do a research on this. Note that again, there are several monitoring tools like PRTG that can monitor bandwidth. To know which string to use, you need to check on a management information base (MIB) available on the Cambium Networks downloads page for a specific product and add into the monitoring tool.
Depending on the tool you have, search how to add specific products MIBs.
Let me know if you get this.
Sincerely yours,
Niragira Olympe
