How to leave 4 chains not connected on a 4500C Ap
Hi Guys.
Just a straight question out of curiosity please.
If I have a 4500C AP and used 4 out of the 8 rpSMA connectors to connect a 4x4 Antenna, can the other 4 ports be empty for future use? or do I need any sort of terminator to protect the radio or myself from outer Rf?
Cheers
You should use a dummy load on all unused RF ports as there is no way to disable or reduce the power on unused ports.
You should be able to use an RPSMA Dummy Load, something like these.
