how to manage extension AP
Greetings all,
I have extended my network using a paired SM n AP. I need to know how to manage the remote AP, I need to know the configs of the SM (layer2 or layer3 ) plus the IP addressing on the AP to achieve remote administration of the AP.
Rajesh
Hi ,
how are u? Well I suppose you have not made your ip public. Go into the AP and SM and select the option PUBLIC near the ip address. You should then be able to access your AP and SM remotely.
thanx
