Summary: This article describes how to manually upgrade the XV series Aps through the Aps Web Management Interface (WMI).
- Log in to the AP via the Web Management Interface by loading its IP address in a Web browser.
- From the Menu system on the left hand side, click the Operations option and under Fimware Update, choose the appropriate upgrade image and then select Upgrade Firmware.
- When the Upgrade has started, you will see a progress notification and a completion notification.
- Select Reboot in the top right corner to complete the upgrade.
