How to set a static IP address for cnMatrix switch from cnMaestro.
Summary:
This article presents configuring static IP address for cnMatrix switch from cnMaestro switch groups.
Prerequisite:
The cnMatrix switch version must be 3.0 or above to support Switch Groups.
Steps:
       1) Create a Switch Group by navigating to Configuration > Switch Groups.
      2) Configure DNS server addresses from Switch Groups > Management tab.
          3) Configure Default Gateway address from Switch Groups > Network tab.
    4) Navigate to Configuration page > select the Switch Group and expand the Advanced Settings section >
       VLAN Interface > click on Edit button.
              5) Now disable DHCP Client flag then configure required IP Address and Netmask, click on Update button
        6) Click on Apply Configuration.
You need to select VLAN Interface first, and unselect DHCP Client.
Thanks.
