How to test cnPilot E400 Router Throughput
the throughput of my clients connected to my cnPilot E400 (cnP) is comparably low in the 10Mbit/s range (see iperf3 test results below). I don't know if the problem is on the wireless side of things or if for some reason there is a problem in the wired connection between the cnP and the rest of the network.
The cnP is connected with a CAT6 cable to a Netgear GS110TP PoE smart switch (switch) that provides both network and PoE to the cnP.
Is anything wrong or not recommended with this setup? I could also use the cnP's PoE injector, but I'd rather us the switch's PoE for a few reasons.
Both, the switch and the cnP show the link speed to be 1000Mbp/s. My internet provider's router shows the connection to the cnP as 10Mbit/s, though I am not sure how it determines that as it's not directly connected and I don't pay too much attention to that. It shows the same for a Raspberry Pi while I could confirm the Pi has 100Mbit/s in accordance with the Pi's specs.
I test all connections between computers on my network using iperf3. Is there anything comparable I could use to test the connection of the router's LAN connection?
Klaus
P.S.: Here is the perf3 output between a wire connected server and my client:
[  5] local 192.168.0.103 port 50573 connected to 192.168.0.5 port 5201
[ ID] Interval           Transfer     Bandwidth
[  5]   0.00-1.00   sec  1.22 MBytes  10.2 Mbits/sec
[  5]   1.00-2.00   sec  1.15 MBytes  9.65 Mbits/sec
[  5]   2.00-3.00   sec  1.23 MBytes  10.3 Mbits/sec
[  5]   3.00-4.00   sec  1.10 MBytes  9.24 Mbits/sec
[  5]   4.00-5.00   sec  1.18 MBytes  9.90 Mbits/sec
[  5]   5.00-6.01   sec  1.21 MBytes  10.2 Mbits/sec
[  5]   6.01-7.00   sec  1.02 MBytes  8.57 Mbits/sec
[  5]   7.00-8.00   sec  1.24 MBytes  10.4 Mbits/sec
[  5]   8.00-9.00   sec  1.20 MBytes  10.1 Mbits/sec
[  5]   9.00-10.00  sec  1.12 MBytes  9.36 Mbits/sec
[  5]   0.00-10.00  sec  11.7 MBytes  9.79 Mbits/sec                  sender
[  5]   0.00-10.00  sec  11.7 MBytes  9.79 Mbits/sec                  receiver
iperf Done.
When connecting my client to the switch I get pretty reasonable 950Mbit/s.
In the meantime I've changed one setting to disable 802.11w State as suggested in another discussion. If I am very close to the router with direct line of sight I can now get close to 100Mbit/s on 5GHz. Is that about the best I can expect, or are there any chances it may go closer to actual GB speeds? Could this still be a problem with the link between the cnP and the switch?
For reference, I get connection speeds of around 170Mbit/s on 5GHz with my provider's router through the basement ceiling.
Klaus
[  5] local 192.168.0.103 port 60147 connected to 192.168.0.5 port 5201
[  5]   0.00-1.00   sec  10.6 MBytes  89.0 Mbits/sec
[  5]   1.00-2.00   sec  10.4 MBytes  87.5 Mbits/sec
[  5]   2.00-3.00   sec  10.5 MBytes  88.1 Mbits/sec
[  5]   3.00-4.00   sec  12.4 MBytes   104 Mbits/sec
[  5]   4.00-5.00   sec  12.3 MBytes   104 Mbits/sec
[  5]   5.00-6.00   sec  13.0 MBytes   109 Mbits/sec
[  5]   6.00-7.00   sec  13.0 MBytes   110 Mbits/sec
[  5]   7.00-8.00   sec  11.8 MBytes  98.5 Mbits/sec
[  5]   8.00-9.00   sec  12.8 MBytes   108 Mbits/sec
[  5]   9.00-10.00  sec  11.7 MBytes  98.4 Mbits/sec
[  5]   0.00-10.00  sec   119 MBytes  99.5 Mbits/sec                  sender
[  5]   0.00-10.00  sec   119 MBytes  99.4 Mbits/sec                  receiver
Througput results you have shared are too low. Could you please share tech-support of device?
Thank You.
I'd love to, but I am not sure what you mean by 'tech-support of device'. Are you looking for the software version?
Active Software Version 3.1.1.1-r1
Backup Software Version 3.1.1-r16
Device-Agent Version 2.62
  • Login to UI of device and navigate to operation's tab.
  • Click of Dowload Tech-support Tab
  • Please share the file which is auto downloaded on your PC/Laptop.
Thank You.
I have the tar.gz file, but for some reason I don't seem to be able to attache it here.
Please email it to shashank.tadakamadla@cambiumnetworks.com.
Any updates on this?
can't we run speed test between ap and client using SpeedFlex tool.
on ap enable Wi-Fi Perf under operations tab and client install SpeedFlex App (available for iOS and Andriod OS)
