mac-telnet isn’t working for me, I’m using version 4.6.1, trying to connect from an ePMP 3k to a Force 300-13L, both have mac-telnet and the telnet service enabled. Is this a bug?
Hello everyone! Which software are you using to connect via mac telnet? Or if you are using binaries, where can I download them to execute via command line interface?
it works from linux mac-telnet client and from Mikrotik RB. Of course, between radios themselves.
You need to use wireless mac address. First prompt will need mac-admin/mac-admin credentials.
Then it it will show hostname and normal admin/your_password prompt.
Hello Andrii, thank you very much!
I have a question: What does it mean when you say “between radios themselves”? Can you explain that to me please?
Thank you.
I mean that our radio has mac-telnet client on board also. So, if you have 2 connected radios, you can access one from another. For example, when the radios are linked but there is some problem in networking configuration.
