How upgarde 10M SM to Advantage SM??
Can 10M SM be upgarded to Advantage SM only by software?
If not ,how shall we do ?
Thanks.
I believe you will have to purchase the Canopy Advantage SM…it is a different part number and a little different hardware.
As I understand if you have Advanced Logic board in modules it is posible to un lock them with activation key that could be orderd from Motorola.
Modules for 5.4GHz band are AL so if you orderd those it could be adventage when you buy activation code.
