jzkkn51
(jzkkn51)
#1
I have 2 cnPiolot E410 AP’s. I have 2 printers that were connecting wireless with no issues running on 3.11.4.1-r3
Once update to both 4.1-r3 and then to 4.1.1-r5 these two printers will not connect. Has anyone else seen this?
HP printers are HP Officejet 6700 and HP Officejet 8600
PFR
(Pshemo (przemo))
#2
With Epson printer no problem.
Check Band steering (in WLAN)
If it is ON, try to Disable and check connection from the printers
jzkkn51
(jzkkn51)
#3
Thanks for quick response. That option is disabled.
PFR
(Pshemo (przemo))
#4
Please go to AP->Notifications->Events.
Try to find in the logs moment when the printer try to connect.
Take sceenshot with error and put here please.
CAM_TSK
(CAM_TSK)
#5
could you please share tech-support via email to sta001@cambiumnetworks.com
Please do share MAC address of devices via email to analyze logs.
jzkkn51
(jzkkn51)
#7
just sent you the tech logs
jzkkn51
(jzkkn51)
#8
SOLVED
There is a setting under WLAN Advanced that was set to optional and we needed to set to disabled. The settings is
policies.labels.802.11w_State
Thank you Shashank
