I have problems trying to upgrade my connectorized epmp AP from version 2 to version 2.3.4, any advice?
The process is failing after it start initializing when send me the "wrong package message"
THe device is an epmp 1000 connectorized AP...
How are you trying to update it, via the console or manual upload?
As long as your using the correct firmware it should work, which one are you using?
ePMP-NonGPS_Synced-v2.3.4.tar.gz?
Sorry I didnt saw your answer, however I am doing it from the browser directly trought the web administration sesion..
I finally did it. My mistake! I was open the .rar archive and them traying to upload a single .bin file...
