Hello,
The 450i AP, 450i BHM/BHS should use the:
N000000L034A POWER SUPPLY, 30W, 56V – Gbps support
For the new 900 Mhz product, beware that the SM is based off the 450 platform and should use the:
N000900L001A Gigabit Enet Capable Pwr Supply for ePMP Sync AP (spare) and PMP450
The N000000L034A is a 56 VDC, 30W power supply that will operate any of the 450i radio equipment in standalone mode (i.e. not being powered by CMM). Note that this PSU requires an IEC60320 Type C5 AC Line cord, part numbers are listed below. These are the same line cords that are used with the N000900L001A, and are not new parts.
This supply can be used instead of N000065L001B, provided you’re not planning to use the AUX port with a device that may exceed 10 Watts.
Pictures:
Part Number |
Description |
MSRP (USD) |
N000000L034A |
POWER SUPPLY, 30W, 56V - Gbps support |
$25 |
Optional AC Line Cords | ||
N000900L007A |
CABLE, UL POWER SUPPLY CORD SET, US |
$5 |
N000900L008A |
CABLE, UL POWER SUPPLY CORD SET, EU |
$5 |
N000900L009A |
CABLE, UL POWER SUPPLY CORD SET, UK |
$5 |
Below is the list of compatible parts (450i platform parts):
Part Number |
Description |
C009045A001A |
900 MHz PMP 450i Connectorized Access Point |
C050045A001A |
5 GHz PMP 450i Connectorized Access Point (ROW) |
C050045A002A |
5 GHz PMP 450i Connectorized Access Point (FCC) |
C050045A003A |
5 GHz PMP 450i Connectorized Access Point (EU) |
C050045A004A |
5 GHz PMP 450i Connectorized Access Point (DES Only) |
C050045A005A |
5 GHz PMP 450i Integrated Access Point, 90 degree (ROW) |
C050045A006A |
5 GHz PMP 450i Integrated Access Point, 90 degree (FCC) |
C050045A007A |
5 GHz PMP 450i Integrated Access Point, 90 degree (EU) |
C050045A008A |
5 GHz PMP 450i Integrated Access Point, 90 degree (DES Only) |
C050045A015A |
5 GHz PMP 450i Connectorized Access Point (IC) |
C050045A016A |
5 GHz PMP 450i Integrated Access Point, 90 degree (IC) |
C050045C001A |
5 GHz PMP 450i Connectorized Subscriber Module |
C050045C002A |
5 GHz PMP 450i SM, Integrated High Gain Antenna |
C050045B001A |
5 GHz PTP 450i END, Connectorized (ROW) |
C050045B002A |
5 GHz PTP 450i END, Integrated High Gain Antenna (ROW) |
C050045B003A |
5 GHz PTP 450i END, Connectorized (FCC) |
C050045B004A |
5 GHz PTP 450i END, Integrated High Gain Antenna (FCC) |
C050045B005A |
5 GHz PTP 450i END, Connectorized (EU) |
C050045B006A |
5 GHz PTP 450i END, Integrated High Gain Antenna (EU) |
C050045B007A |
5 GHz PTP 450i END, Connectorized (DES Only) |
C050045B008A |
5 GHz PTP 450i END, Integrated High Gain Antenna (DES only) |
C050045B015A |
5 GHz PTP 450i END, Connectorized (IC) |
C050045B016A |
5 GHz PTP 450i END, Integrated High Gain Antenna (IC) |
If there are any questions or comments, feel free to post them below.
Akshay Rana.
