Is there an inline power adapter that I can use to power the e400 AP from my Cisco POE switch?
the E400 supports standard 802.3AF PoE, so if thats what the Cisco switch does, you should be able to plug it in as-is.
(may need to enable poe-out on the Cisco with typically the 'power inline' command)
Doh.
Thank you.
I bought a handful of the inline converters because my Force 180s use them. I didn't even think to try it without the converter in the box and just plug straight into my switch. It worked.
