I'm attempting to install Cambium's Wireless Manager on a CentOS 7 server with a few hiccups. Everything installs fine as I walk through the Server Guidelines and Setup guide until I hit this error message when executing the downloaded .run file:
Attemping to install the packages it requires just throws a "No package db4 available" error. Is there a repo I need to add or what is my next step here? I've ensured that all the required packages mentioned in the guide are indeeded installed. Thanks for the help in advance!
That's exactly what I needed! Each of the packages I was missing had a ".i686" extension yum install wasn't recognizing when I went to install the package.
Well it looks like I got past one hurdle and stuck at another. Now it's giving me a "child process exited abnormally" error after the install begins as shown in the attached picture. Any ideas on this error? I'm running a clean install of CentOS 7 64bit and attemping to install WM 4.5.6 64bit just so you know as well.
