I have successfully set a guest access using a External Hotspot. When the user connects to the WLAN, and try to surf the internet using a browser, the E500 intercepts the traffic and redirect it to my web server.
I have successfully set Radius authentication. When I test it using the internal portal, I can authenticate the users successfully.
In my web server I have a standar HTML form in order to get the username and password, but I need to know how do I have to send that information (username and password) to the Access Point? I mean, usually I have to send that information using some format like:
the login page is required to send the user name and password to AP .
I am attaching here a packet capture as refrence which has all required format and user information in HTTP Post packet . (Please refer packet number 70 )
Im trying to use the External Hotspot of cnPilot E400 by using a radius. But the problem is i dont have a radius server. can help me on what kind of radius server do i need to install and on how to configure it to be able to use in the cnpilot E400. Please !!!
We have a similar setup with an external login page for guest access.
The client connects to the ssid, gets radius authenticated, receives his IP address from DHCP, and can browse to the external captive portal url page.
Here the client can login through LDAP or local token configured on captive portal server.
So we configured to redirect everything through https (and our external captive portal server has a valid Let's encrypt certificate).
But what we are observing is that after the client introduces his credentials (which give a succesfull authentication in the captive portal server logs), the final POST comes as http and not as https, and thus the redirection changes from https to http, and yield a timeout and an invalid certificate (this time the Cambium WLAN AP certificate).
Dear,
We solved this issue through support case with Cambium by setting the redirect mode to http.
Cambium garanteed us that this http traffic exchange is essentialy only for the initial post.
Dear Om, can you please help me too I have an external Hotspot designed to capture username and password and pass them to cnPilot e700 then to external radius server for authentication but I don’t know how to capture the user inputs and pass them to this APs please help
