Want to know the integration process with Twilio sms gateway have done configuration as per the my knowledge but not getting an SMS if i try to send from cnmaestro guest captive portal and gettign and error called failed to send sms
attached is the detailed configuration have done kindly check and help me on this.
Hi Hungcnet,
SMS integration is a very simple process. We can help you fix the problem. Please send an email to this email ID anv100@cambiumnetworks.com with below problem details.
Please share the cnMaestro version and AP version too.
