We have an AP cluster within 4.8 miles of another AP cluster running on 900MHz. Is it ok to have both AP clusters using frequencies 906, 915, and 924? I guess as long as they are using different color codes? Or should we use different frequencies?
I am guessing both clusters are yours?
No, one cluster is another company’s.
There are a lot of variables with this. Are both clusters timed by a CMM?
Our is timed by a GPS & CMM yes, I’m not sure about the other one but I would guess it is also.
Are you aware of the direction that the competitors’ APs are pointing in comparison to yours?
Well it is a cluster just like ours, so there are 6 APs like ours. In terms of directions I don’t know exactly which way, but I’m sure that some are pointing towards ours probably.
Download the Ap User Guide…
http://motorola.canopywireless.com/fp/downlink.php?id=f01c9812fdf6ef9ee55f471401b05da6
…and read pages 50-57 for detailed look at multiple clusters.
Aaron
