3-4 months ago we begin to deploy CN201p units as endpoints for our 30x30 and 60x60 fiber to the premise clients. We are experiencing a very high number (almost 100%) of reports of these installations losing Internet and SIP connectivity for time periods of 30 seconds to 3 or 4 minutes. This is reported to ocurr several times a day (they tell us 5-10 times a day)
Field techs going to investigate always find the 201 inaccessable via the web interface when they arrive. 2 different conditions noted when trying to access the 201 via html interface. Either see a text formated screen or the html interface screen is present but it will not repsond to the known access credendials. Upon power cycle the unit is again responsive as should be.
We are seeing this issue very consistently and continue to investigate. We have tested the fiber circuits extensively and see no issues there. We are also seeing some number of these same reports from our Wireless customers especially businesses on higher throughput levels.
There are 2 things we have seen that seem to make these issues disappear. #1 is that we schedule a reboot from within the 201 for 2-3 times per week. #2 is that in 2 of these installations we replaced the 201 with a competing product (DrayTek) and the issue vanished. It if far preferable for us to use the 201 as out entire network is Cambium based and we are beginng deployment of Maestro and need this as our management tool.
We have encountered these reports on units with no ATA provisioned in the 201. With ATA provisioned in the 201 and with and without Grandstream 4 port ATA behind the 201.
We are not comfortable with programmed reboots of this number of times.
Anyone else experiencing this issue?
