We are experiencing intermittent instability on a wireless link using a Cambium PTP650 device.
The behavior is as follows:
In idle conditions (no traffic), the link remains stable for long periods (up to 30+ hours).
Under traffic load, the link becomes unstable and disconnects intermittently.
During these events, latency spikes occur (up to 10 seconds).
Power cycling the PoE temporarily restores connectivity.
The radio itself does not reboot, and uptime remains continuous.
Troubleshooting Steps Performed:
1. PoE Power Supply Check
Replaced the PoE injector once (with a different unit)
Issue still persists
2. Load vs Idle Testing
Connected directly to a laptop → stable (no issues)
Connected to production network → instability under load
3. Long-Term Ping Test
Continuous ping over several hours
Observed intermittent latency spikes (up to 10 seconds
4. Radio Logs
Observed Main PSU Port Status toggling (Up/Down)
Registration timeouts occurred
Suggests Ethernet layer instability
